Thanks for the nice small example. This is not a ReaxFF problem. Rather, you
used NEB without an atom map. The documentation tells you not to do this.
You can get the same behavior in the NEB examples by the following edit to
in.neb.hop1:
#atom_modify map array sort 0 0.0
atom_modify sort 0 0.0
Aidan
