NEB fixes the first and final images?
Dear LAMMPS users,
Recently I used the NEB function in LAMMPS to calculate the transition path of Silicon atom on amorphous Si surface. All the first/last images were fully optimized using CG method, and it can be verified that they were local stable configurations. For most cases, NEB can provide reasonable results, however, I found some strange cases. After NEB calculations, the first/last images move to a nearby stabler configuration. So my question is, if the NEB implementation in LAMMPS fixes the first and last images? In principle, they should be fixed during NEB and only the intermediate images can be relaxed. I dug into the source code and checked min_fire.cpp, neb.cpp, and fix_neb.cpp, and none of them shows such constraint. Before modifying the source code, can I have any way to realize the fix in NEB?
Furthermore, I found that for some cases NEB completely failed. The total potential energy becomes a very large value which means that the system is melted after adding only one adatom on the surface. Do I have better way to calculate the transition path in LAMMPS?
Regards,
Gang
Dear LAMMPS users,
Your first/last replica might not have been relaxed enough. That happen
often with CG, with the stopping criteria "Line search alpha equal
zero". Since NEB is perform with Quickmin/Fire, you might want to relax
your initial/final structure with the Quickmin/Fire, to a fore norm
lower than the one used by the NEB.
From my personal experience, NEB calculations can be tricky to converge.
I often tune the parameters (spring force, normal spring force,
timestep, number of intermediate configurations, etc.) in order to have
a converge path. A correct set of parameter for a given system, might be
not good with another one (actually, that is often the case in MS/MD...).
Also, quickmin is slower than fire, in some case it i also more stable
(i.e. the system do not "melt" during the "climbing" stage).
Maybe you could paste here the exact command you are using for your NEB?
Julien
