Lammps Users,
I am running into NAN values for the reaction coordinates. I only seem to have this problem if the system converges before the maximum number of iterations specified in the neb command are met.
Any ideas would be appreciated.
INPUT:
variable N string “I1”
variable A string “I1.1000K”
variable c equal 3.5710425743336587
variable t equal 1000.0
variable u uloop 6
boundary s p p
atom_style atomic
lattice fcc $c
Read data and set up simulation
atom_modify map array sort 0 0.0
read_data min.0.data
EAM potential – Ni
pair_style eam/alloy
pair_coeff * * potentials/ni1.set Ni Ni Ni Ni Ni
mass * 58.710
neighbor 1.5 bin
group LB type 4
group RB type 5
group GB type 1 2
group GBL type 1
group GBR type 2
thermo 5
thermo_modify lost warn flush yes
Computes
compute CENTRO all centro/atom fcc
compute CNA all cna/atom 3.08
Prevent rigid body motion due to non-periodic x-boundary
fix lbforce LB setforce 0 NULL NULL
fix rbforce RB setforce 0 NULL NULL
dump gdump all atom 100 dump.$A.neb.$u
dump_modify gdump sort id
timestep 0.001
#neb required commands
fix nebatoms GB neb 0.001 #set active atoms
min_style fire
#neb run
#neb with intermediates given
variable i equal part
neb 1.0e-12 1.0e-12 14 14 7 each coord.$i.xyz
MASTER LOG FILE
LAMMPS (7 Jan 2014)
Running on 6 partitions of processors
Step MaxReplicaForce MaxAtomForce GradV0 GradV1 GradVc EBF EBR RDT RD1 PE1 RD2 PE2 … RDN PEN
0 1.1742183 0.85733174 0.1515361 1.0321598 1.1742183 0.09060015 0.024176807 0 0 -143622.28 nan -143622.22 nan -143622.19 nan -143622.21 nan -143622.23 nan -143622.22
7 1.1742172 0.8573311 0.15153589 1.0321588 1.1742172 0.090600026 0.024176778 0 0 -143622.28 nan -143622.22 nan -143622.19 nan -143622.21 nan -143622.23 nan -143622.22
Climbing replica = 3
14 1.1742161 0.85733045 0.15153568 1.0321578 1.1742161 0.090599901 0.024176749 0 0 -143622.28 nan -143622.22 nan -143622.19 nan -143622.21 nan -143622.23 nan -143622.22
