Hi Altruist,
I am trying to create LAMMPS files for SDS (sodium dodecyl sulfate) using moltemplate in Linux. When I run the system.lt file, then it is showing an error “The number of columns in your data file does not match the LAMMPS atom_style you selected. Use the -atomstyle command line argument.)”. I have double checked everything, but couldn’t identify the problem. I checked the same type of work with decane molecules. That worked fine. Would you like to help me figuring out the problem? I badly need help in this case. I have attached the required files for your convenience. I am also copying @jewettaij here if he could help me.
Sincerely,
Akash Talapatra
MS student, Virginia Tech
forcefield.lt (1.5 KB)
surfactant.lt (10.5 KB)
system.lt (601 Bytes)
