Need help in the lattice custom command to generate L10 FCC crystal structure
Sorry for the repost. Seems a problem with the last mail !!
Anyone using the lattice custom command to generate L10 FCC crystal structure, I kindly request you to share the command. The L10 crystal structure of the FePd crystal is attached with the mail. I will also appreciate the alternative ways of generating the crystal structure.
Thanks and regards,
Rakesh
please explain where the problem is.
the purpose of a mailing list is not to
satisfy "please do my work for me" requests,
but rather solve problems. so please ask a
specific question explaining what you tried
and what the errors are and where you
suspect the problem is.
this is a very simple crystal structure.
if all else fails, you can always construct
a data file with the coordinates and use
replicate.
