Need help with Buckingham/Coulomb potential.
Hi users,
I am trying to use the pair_style buck/coul/cut and want to use a different global cut off for Buckingham and Coulomb for SiO2.How can I determine these cutoff values for a box with size Nx=8, Ny=10 and Nz=8.
Also, from the lammps info page(http://lammps.sandia.gov/doc/pair_buck.html) , A, rho, C, cutoff and cutoff2 need to be defined for each pair of atom types while using the pair_coeff command. I have 2 atom types Si and O. So, should I be having 2 pair_coeffs defined?
Attached is my lammps input script with an assumption that the cutoff and cutoff 2 values are the same in the pair_style and pair_coeffs commands. The compiler throws an error - All pair coeffs are not set.
Could some body please clarify this for me.
Regards,
Saketh.
SilicaError.txt (1.36 KB)
Hi users,
the cutoff is determined by the parametrization, not the box size.
Also, from the lammps info page(LAMMPS Molecular Dynamics Simulator)
no, you need three. one for Si-Si, one for Si-O and
one of O-O. sometimes the parameters for the mixed
set (Si-O) can be derived from mixing rules. not sure
about this case though. the paper where you take/took
the potential parameters from should be explaining this.
you probably are missing the mixed term.
Hi
this is wrong:
pair_style buck/coul/cut 10.0
pair_style buck/coul/cut 10.0 8.0
pair_coeff 1 1 1282.9 0.321 10.61 10.0
pair_coeff 1 1 1282.9 0.321 10.61 10.0 8.0
should be like this:
pair_coeff 1 2 xxx.xx xxx.xx xxx.xx
pair_coeff 2 2 xxx.xx xxx.xx xxx.xx
It does not really make sense to use a shorter cutoff for coulomb then for the buckingham part (the latter is the long range interaction).
If you want longer rang coulomb interactions do something like:
pair_style buck/coul/cut 10.0 15.0
But using a long range coulomb solver (i.e. pppm) will most likely be faster and more accurate than this.
Cheers
Christian
-------- Original-Nachricht --------
