Hrushikesh,
Thanks for the quick response!
See my last comment to Dr. Jain, I believe it was an issue with FireWorks itself and not my lpad configuration. I was still able to run commands such as lpad get_wfs without issue.
As requested, here’s the full error:
(/home/knykiel/.conda/envs/2022.10-py39/atomate) lpad rerun_fws -s FIZZLED
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/bin/lpad", line 8, in <module>
sys.exit(lpad())
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/scripts/lpad_run.py", line 1553, in lpad
args.func(args)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/scripts/lpad_run.py", line 643, in rerun_fws
lp.rerun_fw(int(f), recover_launch=l, recover_mode=args.recover_mode)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/core/launchpad.py", line 1716, in rerun_fw
updated_ids = wf.rerun_fw(fw_id)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/core/firework.py", line 1016, in rerun_fw
m_fw._rerun()
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/core/launchpad.py", line 2075, in _rerun
self.full_fw._rerun()
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/core/launchpad.py", line 2175, in full_fw
self._get_launch_data(launch_field)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/core/launchpad.py", line 2190, in _get_launch_data
fw = self.partial_fw # assure stage 1
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/core/launchpad.py", line 2168, in partial_fw
self._fw = Firework.from_dict(data)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 159, in _decorator
new_args[0] = {k: _recursive_load(v) for k, v in args[0].items()}
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 159, in <dictcomp>
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 120, in _recursive_load
return {k: _recursive_load(v) for k, v in obj.items()}
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 120, in <dictcomp>
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 123, in _recursive_load
return [_recursive_load(v) for v in obj]
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 123, in <listcomp>
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 115, in _recursive_load
return load_object(obj)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 337, in load_object
return cls_.from_dict(obj_dict)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/fireworks/utilities/fw_serializers.py", line 118, in _recursive_load
return json.loads(json.dumps(obj), cls=MontyDecoder)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/json/__init__.py", line 359, in loads
return cls(**kw).decode(s)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/monty/json.py", line 497, in decode
return self.process_decoded(d)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/monty/json.py", line 443, in process_decoded
return cls_.from_dict(data)
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/monty/json.py", line 194, in from_dict
decoded = {k: MontyDecoder().process_decoded(v) for k, v in d.items() if not k.startswith("@")}
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/monty/json.py", line 194, in <dictcomp>
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/monty/json.py", line 405, in process_decoded
obj = self.process_decoded(d["@bound"])
File "/home/knykiel/.conda/envs/2022.10-py39/atomate/lib/python3.11/site-packages/monty/json.py", line 195, in from_dict
return cls(**decoded)
TypeError: RelaxSetGenerator.__init__() got an unexpected keyword argument 'auto_kspacing'
Kat Nykiel
