I have a new radial, two body pair style in lammps, obtained modifying
pair_morse.cpp and pair_morse.h. Everything seems to work well, but I wanted to
ask if there can be compatibility issues with the heat current computation
(compute_heat_flux.cpp) and if there is something to be modified that can be
tricky (I have no runtime errors).
Thanks a lot,
Aris
fix heat operates on the kinetic energy, while pair styles usually
only affect the potential energy, why should there be a conflict?
so unless your pair style does something exotic that will mess up the
model that you want to establish with fix heat, i don't see why there
should be a problem.
