Dear mailing list,
I am implementing a new potential that will use the KSPACE integration, but I am experiencing a compilation error
that I cannot understand and whose solution I cannot find on the manual.
I did the following:
created a directory CTIP in src/
copied there the files src/KSPACE/pair_coul_long.*
renamed them as pair_ctip.(h and cpp)
changed in them the names
PairCoulLong -> PairCTIP
coul/long -> ctip
in *.cpp put #include “pair_ctip.h”
and nothing else (I just want to see whether it is compiled and included)
- added the name ctip in the Makefile, section PACKAGE
When compiling I do:
make yes-kspace
make yes-ctip
make openmpi (I work on ubuntu)
The compilation gives:
"make[1]: Entering directory /home/daniele/CODES-vari/LAMMPS-Versions-pavilion/lammps-1Feb14.DS-99.working/src/Obj_openmpi' mpic++ -O2 -funroll-loops -fstrict-aliasing -Wall -W -Wno-uninitialized -DLAMMPS_GZIP -DFFT_FFTW -M ../remap_wrap.cpp > remap_wrap.d [...] mpic++ -O2 -funroll-loops -fstrict-aliasing -Wall -W -Wno-uninitialized -DLAMMPS_GZIP -DFFT_FFTW -c ../force.cpp In file included from ../style_pair.h:17:0, from ../force.cpp:84: ../pair_ctip.h: In constructor ‘LAMMPS_NS::Force::Force(LAMMPS_NS::LAMMPS*)’: ../pair_ctip.h:16:1: error: ‘PairCTIP’ was not declared in this scope ../pair_ctip.h:16:1: error: no matches converting function ‘pair_creator’ to type ‘std::map<std::basic_string<char>, LAMMPS_NS::Pair* (*)(LAMMPS_NS::LAMMPS*)>::mapped_type {aka class LAMMPS_NS::Pair* (*)(class LAMMPS_NS::LAMMPS*)}’ ../force.h:110:38: error: candidate is: template<class T> static LAMMPS_NS::Pair* LAMMPS_NS::Force::pair_creator(LAMMPS_NS::LAMMPS*) make[1]: *** [force.o] Error 1 make[1]: Leaving directory /home/daniele/CODES-vari/LAMMPS-Versions-pavilion/lammps-1Feb14.DS-99.working/src/Obj_openmpi’
make: *** [openmpi] Error 2
I cannot understand this error.
I inserted just two files *.h and *.cpp as suggested in the manual (Extending and Modifying Lammps).
I already implemented a potential without KSPACE (Reference Free MEAM) and I didn’t get this error.
Any idea of the reason and any suggestion on how to proceed ?
Many thanks
Bests,
Daniele Scopece
Dear mailing list,
1) created a directory CTIP in src/
2) copied there the files src/KSPACE/pair_coul_long.*
3) renamed them as pair_ctip.(h and cpp)
4) changed in them the names
coul/long -> ctip
in *.cpp put #include "pair_ctip.h"
included)
5) added the name ctip in the Makefile, section PACKAGE
make yes-kspace
make yes-ctip
`/home/daniele/CODES-vari/LAMMPS-Versions-pavilion/lammps-1Feb14.DS-99.working/src/Obj_openmpi'
'LAMMPS_NS::Force::Force(LAMMPS_NS::LAMMPS*)':
../pair_ctip.h:16:1: error: 'PairCTIP' was not declared in this scope
../pair_ctip.h:16:1: error: no matches converting function 'pair_creator' to
type 'std::map<std::basic_string<char>, LAMMPS_NS::Pair*
LAMMPS_NS::LAMMPS*)}'
didn't get this error.
the error is likely in your pair_ctip.h file, which doesn't seem to be
adapted correctly.
Dear mailing list,
coul/long -> ctip
included)
so you didn't change the ifdef that prevents multiple inclusion?
biiig mistake.
Yes: that was the problem indeed !
I needed also to change the lines in *.h
#ifndef LMP_PAIR_COUL_LONG_H
#define LMP_PAIR_COUL_LONG_H
into
#ifndef LMP_PAIR_CTIP_H
#define LMP_PAIR_CTIP_H
and everything compiles fine.
So those consider the case where the user put two entries with two potentials, when no hybrid being considered.
Is that the case ?
Thank you
Daniele
into
Is that the case ?
no. it does what i said it does.
it looks to me, like you need to pick up your book about C/C++
programming and re-read the chapter about the preprocessor.
into
to be very clear on this subject, there can be only one(1) active pair
style at a time. the force class only hold one pointer to a pair
class.
