Hi all,
I am trying to run lammps using gpu package and I am a beginner in using gpus. I am using tip4p water model along with eam potential for copper. I get the error of "Pair style lj/cut/tip4p/long requires newton pair on (…/pair_lj_cut_tip4p_long.cpp:457)
Cuda driver error 4 in call at file ‘geryon/nvd_device.h’ "
When I turn newton pair on, I get the error of “Cannot use newton pair with eam/gpu pair style”
I really appreciate it if you can help me overcome this problem.
Hi all,
(../pair_lj_cut_tip4p_long.cpp:457)
Cuda driver error 4 in call at file 'geryon/nvd_device.h' "
When I turn newton pair on, I get the error of "Cannot use newton pair
with eam/gpu pair style"
don't use the GPU package. with running lj/cut/tip4p/long and the
neighborlist on the CPU, there is very little to gain from GPU
acceleration anyway.
