I‘m using the electron atom style, which shows no bonds allowed, how to add the bonds, just modify the atom_vec_electron.cpp or modify other code.
Thank you,
Zhou
Thank you,
Zhou
How about using atom style hybrid?
Thanks for replying, I can now add bonds successfully, but it will cause pairwise force disappear, I want to retain the pairwise force, what should I do?
This is controlled by the special_bonds command — LAMMPS documentation
The default is to remove 1-2, 1-3, and 1-4 non-bonded pairs from the neighbor list because the bonded interactions are parameterized directly for the bonded interaction only (otherwise the non-bonded would have to be removed from the bonded to avoid double counting).
If you want to preserve all non-bonded forces and energies, you would need to set
special_bonds lj/coul 1.0 1.0 1.0
Thanks a lot, I’ll check the command carefully.
