no error and no output generated
Hi all,
I have a problem in obtaining output from lammps. I used the following lines in my input file:
#LAMMPS Input file generated by Avogadro
Intialization
units real
dimension 3d
atom_style full
Atom Definition
read_data data.water
replicate 1 1 1
Settings
velocity all create 298.15 4928459 rot yes mom yes dist gaussian
fix ensemble all nvt temp 298.15 298.15 100 tchain 1
timestep 2.0
Output
dump 1 all xyz 20 water.xyz
thermo_style custom step temp pe etotal press vol
thermo 50
Run the simulation
run 1000
And I run lammps using the following commands:
./lmp_mpi -in in.water
I got this message:
LAMMPS (6 Jul 2017)
MPI process rank 0 (n0, p3040) caught a SIGSEGV.
And only a log file is generated. No other files…
What should I do?
the message:
is an error and a very serious one. you should try running without MPI and use the -echo screen flag, so you see after which command of your input LAMMPS segfaults.
most likely this would be during read_data, which in turn means, that your data file is incorrectly formatted.
Dear Axel,
Thanks a lot. Actually the problem was with my data file…
