Hello, everyone!
Trying to reproduce this example I face with the problem that helpers module is not available from the conventional HipHive distribution while it is needed to run the example.
The same is for the tools module required in this example
Can somebody share these modules?
Anton.
are these files not present in the example directories?
If they are shouldnt you be able to import from them?
Ok, the problem was that I was taking the code from the webpage and not from this directory, where the helpers.py script is in.
Thanks for the hint!
