no output from fix ave/chunk command
Dear lammps users,
I want to use rerun command to read snapshots from a dump file to calculate number density in different bins. The dump file has id, type, q, x, y, z, vx, vy, vz, fx, fy, fz of each atom, with timestep ranging from 50,000 to 100,000 and a span of 100 steps. When the rerun command finishes, everything seems fine from my log file, but the output file writen by fix ave/chunk command doesn’t have any other information except the three default head lines. Could you tell me what the reason is and how to solve this problem? The related commands are as follow:
compute define_bin all chunk/atom bin/1d z lower 2.05 units box
fix 1 all ave/chunk 100 500 50000 define_bin density/number norm sample file density_number_of_different_bins.txt
rerun coord.txt first 50100 every 100 dump x y z box yes replace yes
Thanks and look forward to your reply.
Rui
Dear lammps users,
​please always report which version of LAMMPS you are using.
I want to use *rerun* command to read snapshots from a dump file to
everything seems fine from my log file, but the output file writen by *fix
ave/chunk* command doesn't have any other information except the three
replace yes
​you may have too few frames of coordinate data in your dump file.​
thus try with, e.g.:
       400 40000 define_bin density/number norm
