Hi everyone.
I am trying to simulate an indentation of a substrate by a spherical rigid indenter. Anytime I run this simulation, the indenter simply passes through the substrate without permanent deformation of the substrate. Also, I noticed that the velocity command doesn’t work with rigid bodies. My script is as follows:
atom_style atomic
variable latparam equal 5.43
######## SIMULATION BOX
region simulationbox block 0 500 0 500 0 400 units box
create_box 2 simulationbox
mass 1 12.01
mass 2 28.0855
######## SUBSTRATE
lattice fcc ${latparam}
region Si block 0 500 0 500 0 350 units box
create_atoms 2 region Si units box
group substrate region Si
######## ZONING OF SUBSTRATE
region mobile block 0 500 0 500 10.86 350 units box
group upper region mobile
region thermobile block 0 500 0 500 5.43 350 units box
group middle region thermobile
group thermo subtract middle upper
group fixed subtract substrate middle
neighbor 2.0 bin
######## INDENTER
lattice fcc 3.57
region diamond sphere 100 100 360 8 units box
create_atoms 1 region diamond units box
group indenter region diamond
fix 12 indenter rigid single
######## INTERATOMIC POTENTIAL
pair_style hybrid morse 9 tersoff tersoff
pair_coeff * * tersoff 1 SiC.tersoff C NULL
pair_coeff * * tersoff 2 Si.tersoff NULL Si
pair_coeff 1 2 morse 0.435 4.6875 1.9475 1.5
######## INITIALIZE TEMPERATURE
velocity middle create 200 4186532 dist uniform mom yes rot yes
velocity thermo create 200 4186532 dist uniform mom yes rot yes
fix 2 fixed setforce 0.0 0.0 0.0
fix 19 middle temp/rescale 1 200 200 0.5 1.0
fix 70 substrate nve
dump equitempsrecent all xyz 100 dump.equitempsrecent
run_style verlet
thermo_style custom step temp ke pe
thermo 200
reset_timestep 0
run 1000
####### VERTICAL INDENTATIION
fix 100 indenter addforce 0.0 0.0 -0.05
dump vertical200 all xyz 100 dump.vertical200
run_style verlet
reset_timestep 0
run 2500
unfix 100
unfix 70
Any assistance will be most appreciated.
Chionye Okwuashi
MS student,
Department of Mechanical Engineering,
Parks College of Engineering, Aviation, and Technology,
Saint Louis University.
