I try to apply torsion on a cylinder by fixng one end and rotating the other a constant increment of the twisting angle , After each rotation increment , I want to relaxe the whole cylinder a certain time while restraining bothsides , However, I don’t want to use fix setforce because I also want to calculate the total torque which is related to the atoms forces of the loading end.
Can I just use “fix move rotate” but setting a extremely big period , as if the end is restrained and keeping the atoms forces?.
thanks in advance
