I am trying to find symmetrically inequivalent T-atoms in a crystal structure (zeolite).
Does anyone happen to know any package that can help with that? I see that pymatgen does have options for symmetry analysis, but I will need some help to understand it.
Here is a snippet of the code that I tried on a .cif file, (anyone interested in checking on the cif file, https://europe.iza-structure.org/IZA-SC/mat_cif.php?ID=CHA_0 )
The module from pymatgen,
pymatgen.symmetry package — pymatgen 2023.10.4 documentation
import pymatgen.core as pmg
from pymatgen.symmetry.analyzer import cluster_sites
structure = pmg.Structure.from_str(open("./CHA.cif").read(), fmt="cif")
sites = cluster_sites(structure, tol=0.1)
The output is,
(None,
defaultdict(list,
{(4.99070644043773,
Comp: Si1): [PeriodicSite: Si (8.2387, 1.1508, 5.5161) [0.8954, 0.1241, 0.6673], PeriodicSite: Si (5.5368, 8.3047, 0.0694) [0.6673, 0.8954, 0.1241], PeriodicSite: Si (0.6537, 6.1886, 7.8040) [0.1241, 0.6673, 0.8954], PeriodicSite: Si (0.4825, 8.3047, 5.5161) [0.1241, 0.8954, 0.6673], PeriodicSite: Si (7.8310, 6.1886, 0.0694) [0.8954, 0.6673, 0.1241], PeriodicSite: Si (6.1157, 1.1508, 7.8040) [0.6673, 0.1241, 0.8954]],
(4.255705851873808,
Comp: Si1): [PeriodicSite: Si (8.0719, 0.9699, 2.4219) [0.8759, 0.1046, 0.3327], PeriodicSite: Si (0.7234, 3.0860, 7.8686) [0.1046, 0.3327, 0.8759], PeriodicSite: Si (2.4387, 8.1238, 0.1340) [0.3327, 0.8759, 0.1046], PeriodicSite: Si (0.3157, 8.1238, 2.4219) [0.1046, 0.8759, 0.3327], PeriodicSite: Si (3.0176, 0.9699, 7.8686) [0.3327, 0.1046, 0.8759], PeriodicSite: Si (7.9007, 3.0860, 0.1340) [0.8759, 0.3327, 0.1046]],
(4.721664892674799,
Comp: O1): [PeriodicSite: O (6.8820, 1.0159, 6.3861) [0.7484, 0.1095, 0.7484], PeriodicSite: O (6.4025, 6.9415, -0.0205) [0.7484, 0.7484, 0.1095], PeriodicSite: O (0.4574, 6.9415, 6.3861) [0.1095, 0.7484, 0.7484]],
(4.255705851873808,
Comp: O1): [PeriodicSite: O (8.0970, 2.3331, 1.5519) [0.8905, 0.2516, 0.2516], PeriodicSite: O (2.1519, 2.3331, 7.9586) [0.2516, 0.2516, 0.8905], PeriodicSite: O (1.6724, 8.2588, 1.5519) [0.2516, 0.8905, 0.2516]],
(6.650526506176671,
Comp: O1): [PeriodicSite: O (8.5779, 6.3230, 7.9598) [0.9768, 0.6818, 0.9768], PeriodicSite: O (8.3564, 9.0599, 5.0007) [0.9768, 0.9768, 0.6818], PeriodicSite: O (5.6105, 9.0599, 7.9598) [0.6818, 0.9768, 0.9768]],
(1.4759151389461997,
Comp: O1): [PeriodicSite: O (2.9439, 0.2147, -0.0218) [0.3182, 0.0232, 0.0232], PeriodicSite: O (0.1980, 0.2147, 2.9373) [0.0232, 0.0232, 0.3182], PeriodicSite: O (-0.0235, 2.9517, -0.0218) [0.0232, 0.3182, 0.0232]],
(3.5640104664911534,
Comp: O1): [PeriodicSite: O (6.8592, 0.0000, 1.9392) [0.7371, 0.0000, 0.2629], PeriodicSite: O (1.8925, 6.8368, -0.6965) [0.2629, 0.7371, 0.0000], PeriodicSite: O (-0.1973, 2.4378, 6.6953) [0.0000, 0.2629, 0.7371], PeriodicSite: O (2.4458, 0.0000, 6.6953) [0.2628, 0.0000, 0.7371], PeriodicSite: O (6.6619, 2.4378, -0.6965) [0.7371, 0.2628, 0.0000], PeriodicSite: O (-0.5533, 6.8368, 1.9392) [0.0000, 0.7371, 0.2628]],
(4.438228227072944,
Comp: O1): [PeriodicSite: O (7.5563, 4.6373, 0.4353) [0.8524, 0.5000, 0.1476], PeriodicSite: O (0.7336, 7.9057, 3.9690) [0.1476, 0.8524, 0.5000], PeriodicSite: O (4.5417, 1.3689, 7.5027) [0.5000, 0.1476, 0.8524], PeriodicSite: O (0.9981, 4.6373, 7.5027) [0.1476, 0.5000, 0.8524], PeriodicSite: O (7.8208, 1.3689, 3.9690) [0.8524, 0.1476, 0.5000], PeriodicSite: O (4.0127, 7.9057, 0.4353) [0.5000, 0.8524, 0.1476]]}))
I used on the zeolite structure called CHA for which there exists one type of T-atom (Si- atom), check below,
