Hello!
I am trying to simulate 4 chains of polymers with salt and MOF using LAMMPS. I get an error while doing simulation in NPT. Although with the same input I have simulated polymers and salt but when I added MOF it is giving an error I don’t understand that why I am getting an error. Can any one explain me?
ERROR on proc 0: Non-numeric box dimensions - simulation unstable (…/pppm.cpp:1885)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
LAMMPS (29 Oct 2020)
Here is my input file
Defining the system
atom_style full
#dielectric 1
bond_style harmonic
angle_style harmonic
dihedral_style opls
improper_style cvff
#special_bonds lj 0.000000 0.000000 1.000000 coul 1.000000 1.000000 1.000000
pair_style lj/cut/coul/long 12.0
pair_modify table 16 # Accuracy of the table used for real space electrostatics
pair_modify mix arithmetic
pair_modify tail no
box tilt large
read_data “/home/lammps/lammps_min_polymer_mof.dat”
kspace_style pppm 1e-6
neighbor 2.0 bin
Setting for output
dump Dump all custom 1000 “min.lammpstrj” id type x y z ix iy iz vx vy vz
thermo_style custom step time cpu pe ke etotal enthalpy temp press vol density cella cellb cellc cellalpha cellbeta cellgamma
thermo 100
Setting to run MD or minimization
>>> SCHEME-1
restart 1000 restart.min
minimize 1.0e-10 1.0e-8 10000 100000
run 10000
Here is my NPT file
Defining the system
atom_style full
#dielectric 1
bond_style harmonic
dihedral_style opls
improper_style cvff
pair_modify tail no
#box tilt large
read_restart restart.min.15000
#read_data “/home/lammps/lammps_min_polymer_mof.dat”
neighbor 2.0 bin
write_restart restart.npt
velocity all create 5.0 30247
dump Dump all custom 1000 “traj_npt_5K.lammpstrj” id type x y z ix iy iz vx vy vz
thermo 100
fix ensemble1 all npt temp 5.0 5.0 0.1 aniso 1.0 1.0 1.0
timestep 0.002
restart 50000 restart.npt
run 100000
unfix ensemble1
Thanks in advance
