I trying to simulate a nano-battery system composed of graphene anode, V2O5 cathode, and 1 M Na2SO4 solution (in TIP4P water model) using Buckingham potential with long-range coulombic interactions. After the minimization step, its showing
Non-numeric positions - simulations unstable.
I have already checked for any overlapping atoms (check log file). However, I can’t seem to find the source of the problem.
Log file:
LAMMPS (2 Aug 2023)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/src/comm.cpp:98)
Reading data file ...
orthogonal box = (-21.009836 -21.003825 -48.74872) to (20.990164 20.996175 42.25128)
reading atoms ...
6287 atoms
scanning bonds ...
4 = max bonds/atom
scanning angles ...
6 = max angles/atom
reading bonds ...
6143 bonds
reading angles ...
8413 angles
special bond factors lj: 0 0 0
special bond factors coul: 0 0 0
4 = max # of 1-2 neighbors
6 = max # of 1-3 neighbors
18 = max # of 1-4 neighbors
18 = max # of special neighbors
special bonds CPU = 0.004 seconds
read_data CPU = 0.049 seconds
Setting atom values ...
2016 settings made for charge
1008 settings made for charge
36 settings made for charge
18 settings made for charge
72 settings made for charge
1855 atoms in group anode
3024 atoms in group water
36 atoms in group cation
90 atoms in group anion
1282 atoms in group cathode
126 atoms in group salt
3150 atoms in group electrolyte
3137 atoms in group electrodes
System init for delete_atoms ...
PPPM initialization ...
using 12-bit tables for long-range coulomb (src/src/kspace.cpp:342)
G vector (1/distance) = 0.29432954
grid = 36 36 100
stencil order = 5
estimated absolute RMS force accuracy = 0.0001410228
estimated relative force accuracy = 9.7934916e-06
using double precision MKL FFT
3d grid and FFT values/proc = 171462 129600
Generated 0 of 28 mixed pair_coeff terms from arithmetic mixing rule
Neighbor list info ...
update: every = 1 steps, delay = 0 steps, check = yes
master list distance cutoff = 10.1
ghost atom cutoff = 10.1
binsize = 5.05, bins = 9 9 19
3 neighbor lists, perpetual/occasional/extra = 2 1 0
(1) command delete_atoms, occasional
attributes: full, newton on
pair build: full/bin
stencil: full/bin/3d
bin: standard
(2) pair coul/long, perpetual
attributes: half, newton on
pair build: half/bin/newton
stencil: half/bin/3d
bin: standard
(3) pair buck, perpetual, skip from (2)
pair build: skip
stencil: none
bin: none
WARNING: Ignoring 'compress yes' for molecular system (src/src/delete_atoms.cpp:140)
Deleted 0 atoms, new total = 6287
grid = 36 36 100
stencil order = 5
2 neighbor lists, perpetual/occasional/extra = 2 0 0
(1) pair coul/long, perpetual
bin: standard
(2) pair buck, perpetual, skip from (1)
pair build: skip
stencil: none
bin: none
Setting up cg style minimization ...
Unit style : metal
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 32.58 | 32.58 | 32.58 Mbytes
Step Time Temp Press E_pair E_coul PotEng KinEng TotEng
0 0 0 151.9199 -114.70089 4648.248 3199.1028 0 3199.1028
40 0.04 0 -2.2943969e+92 -1.0429624e+91 -8.9784382e+15 -1.0429624e+91 0 -1.0429624e+91
Loop time of 25.0864 on 1 procs for 40 steps with 6287 atoms
99.1% CPU use with 1 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = quadratic factors are zero
Energy initial, next-to-last, final =
3199.10281475069 -1.04296241988326e+91 -1.04296241988326e+91
Force two-norm initial, final = 188.79558 8.9120925e+106
Force max component initial, final = 6.7453597 5.6365022e+106
Final line search alpha, max atom move = 4.0430971e-126 2.2788926e-19
Iterations, force evaluations = 40 674
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 15.714 | 15.714 | 15.714 | 0.0 | 62.64
Bond | 0.35178 | 0.35178 | 0.35178 | 0.0 | 1.40
Kspace | 7.4434 | 7.4434 | 7.4434 | 0.0 | 29.67
Neigh | 1.4666 | 1.4666 | 1.4666 | 0.0 | 5.85
Comm | 0.030868 | 0.030868 | 0.030868 | 0.0 | 0.12
Output | 0 | 0 | 0 | 0.0 | 0.00
Modify | 0.024606 | 0.024606 | 0.024606 | 0.0 | 0.10
Other | | 0.05512 | | | 0.22
Nlocal: 6287 ave 6287 max 6287 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 6312 ave 6312 max 6312 min
Neighs: 598147 ave 598147 max 598147 min
Total # of neighbors = 598147
Ave neighs/atom = 95.140289
Ave special neighs/atom = 7.3618578
Neighbor list builds = 88
Dangerous builds = 42
Finding SHAKE clusters ...
0 = # of size 2 clusters
0 = # of size 3 clusters
0 = # of size 4 clusters
1008 = # of frozen angles
find clusters CPU = 0.002 seconds
create bodies CPU = 0.000 seconds
18 rigid bodies with 90 atoms
1.9243786 = max distance from body owner to body atom
grid = 36 36 100
stencil order = 5
Setting up Verlet run ...
Unit style : metal
Current step : 0
Time step : 0.5
Per MPI rank memory allocation (min/avg/max) = 39.58 | 39.58 | 39.58 Mbytes
0 0 0 -nan -1.0429624e+91 -8.9784382e+15 -1.0429624e+91 0 -1.0429624e+91
ERROR on proc 0: Non-numeric atom coords - simulation unstable (src/src/domain.cpp:551)
Last command: run 10000
Thanks in advance.
