Hi, I’ve been trying to download a large dataset of materials (with HasProps.charge_density and fields=material_id). I query the list of materials (for e.g. upto 2000-3000 Hexagonal symmetry samples) in order to write vasp files by first instantiating mpr.get_charge_density_from_material_id(material_id) of the respective materials.
The mpr.get_charge_density_from_material_id(material_id) returns error for multiple samples as follows: NoSuchKey: An error occurred (NoSuchKey) when calling the GetObject operation: The specified key does not exist.
On checking the potential error, I realised that the material-id/key is not present for those particular materials in the AWS S3 buckets (materialsproject-{raw,parsed,build}).
This, prevents me from generating the vasp files in one shot, and I have to restart every time one of the material-id keys doesn’t exist in the list.
Is there a way around this? Should I look into boto3 (python interfacing with AWS systems) and set up some flags where it breaks down/or any other code changes using which I won’t stumble into this problem ?
Thanks a lot for your help in advance!
