The compute com/molecule command will calculate the COM of each
molecule. It cannot be used as input to fix ave/spatial, but you
can output it to a file via fix ave/time with the vector option. Then
post-process it to do your own spatial averaging.
probably not worth the effort. since using the COM. is already quite
an approximation over using all (heavy) atom positions, it usually
doesn't make a difference beyond the statistical (and systematic)
error to simply pick the one atom in the molecule that is closest to
the COM. define a suitable group, and use fix ave/spatial directly.
To Axel: I want to know your method is acceptable in a scientific article?
how *can* you know? make a *&%#&$ test!
before my supervisor suggested me doing this method but which atoms?
see above
For example in Heptane molecules which one should I chose? middle carbon?
besides, I will have problems with rdf calculation. After all, I want to
see above
calculate the rdf for COM-COM of my molecules instead of atom-atoms of my
molecules.
see above.
as i said, using the COM is as artificial a measure as picking a
(random or specific) atom. i am not saying that you *have* to do it,
but that you *may* be able to do it. how good a choice one over the
other is depends very much on the choice of system and molecule.
research doesn't work by blindly doing what you get told. if that were
the case, it would be much easier and cheaper to have a bunch of
robots do the work your are trying to do. you have to use that stuff
sitting between your ears every once in a while, too.
my intention is to teach you something that is called "problem
solving", and to that end make you try other problem solving
strategies than just asking questions until people give up on you.
Anyway, I suggest you teaching philosophy of science.
Sometimes I wonder if you are the artificial brain Ray Kurzweil is building at google. Lots of perseverance but little common sense. Anyways, do as you please. Its your life. I would be very glad for you if you were to prove me wrong.
