Dear LAMMPS user,
During a collision cascade in Fe crystal, I would like to record in a file the number of atoms with a kinetic energy higher than a certain value as a function of time.
For this, I use a the following, which I found in http://lammps.sandia.gov/doc/group.html
compute 1 all ke/atom
compute 2 all reduce sum c_1
thermo_style custom step temp ke c_2
run 0
Here follows atoms with ke > 100 eV)
variable eatom atom “c_1 > 100.0”
group hienergy variable eatom
variable nbatoms equal count(hienergy)
thermo_style custom step temp ke c_2 v_nbatoms
run 2000
However, when I check the value of nbatoms with v_nbatoms in thermo_style command, it is always 0 during the run, when it should be much higher with an initial atom with a kinetic energy of 20 keV.
I also tried creating a dynamic group
group hienergygroup dynamic hienergy var eatom every 1
and count the number of atoms in the group hienergygroup, but same result.
Could anyone give me a hand please ?
Many thanks in advance and best regards,
Christophe
Dear LAMMPS user,
function of time.
run 0
# Here follows atoms with ke > 100 eV)
variable eatom atom "c_1 > 100.0"
run 2000
have you tried this? this is what i would have tried first:
compute heatoms all reduce sum v_eatom
also, have you dumped the energy per atom in a dump file and checked,
if there actually are atoms with a kinetic energy > 100?
Dear LAMMPS user,
function of time.
run 0
run 2000
Yes, it works ! Thanks ! Indeed, this line was missing. I wrongly assumed that the command variable would return the sum.
Christophe
Hi all,
Now it works, I am trying to use this number to determine the number of atoms that have a Ek > 10 eV, close to boundaries. If this number is not null, then I would like the simulation stops.
To do so I wrote the following:
compute 1 atoms_boundary ke/atom
compute 2 atoms_boundary reduce sum c_1
run 0
variable eatom atom “c_1 > 10.0”
compute heatoms atoms_boundary reduce sum v_eatom
variable nbaim equal c_heatoms
if “${nbaim} > 0” then quit
run 2500
At this stage, LAMMPS complains:
ERROR: Compute used in variable between runs is not current (…/variable.cpp:1287)
Is my approach correct ? Or should I use a loop and check every N steps for the value of nbaim ?
Christophe
Hi all,
> result.
run 0
variable eatom atom "c_1 > 10.0"
if "${nbaim} > 0" then quit
run 2500
(../variable.cpp:1287)
this cannot work. all commands in LAMMPS are acted upon immediately.
so the if statement is useless.
yes, you could break the run down into small chunks with "every" or do
a loop, but there is actually a command just made for your specific
need:
http://lammps.sandia.gov/doc/fix_halt.html
I did not know that command. Thanks a lot Axel !
Christophe
yes, you could break the run down into small chunks with “every” or do
need:
I tried it but it does not work. This is what I did:
compute 1 thermal_atoms_in ke/atom
compute 2 thermal_atoms_in reduce sum c_1
run 0
compute heatoms thermal_atoms_in reduce sum v_eatom
fix 10 atoms_boundary halt 1 nbaim > 0
run 2500
LAMMPS complains with the following msg:
ERROR: Unknown fix style (…/modify.cpp:815)
I think I used the right syntax. I am using version 30 July 2016.
Christophe
In my previous mail read “atoms_boundary” in the first compute commands instead of “thermal_atoms_in”. It was correct in the input.
Too old.
You are right. With version from 17Nov16 it works. Thanks again.
Christophe
