LAMMPS version: 290824
Hi, I found something strange in the way the number of OpenMP threads are reported in the log file.
I am running on a cluster that uses PBS as scheduler, with the following settings:
#PBS -l select=4:ncpus=48:mpiprocs=48:ompthreads=96
Hence, I am using 4 nodes, 48x4=192 MPI ranks and 96x4=384 OpenMP threads (i.e. 2 threads per rank).
In the LAMMPS log file I read:
Performance: 2.997 ns/day, 8.007 hours/ns, 34.690 timesteps/s, 1.110 Matom-step/s
92.7% CPU use with 192 MPI tasks x 96 OpenMP threads
which I am almost 100% sure cannot be. Not only this is inconsistent with the PBS settings, but I think it’s physically impossible to run 96 OpenMP threads per MPI rank, when all the physical cores are occupied by MPI processes (the CPUs on the cluster have 24 physical cores and 48 threads, 2 CPUs per node).
So there’s either a bug in the way the log file is written, or PBS is ‘confusing’ LAMMPS for some reason. I would expect to read:
[...] 192 MPI tasks x 2 OpenMP threads
right?
