Please, l have been simulating cutting phenomena using LAMMPS (- using a tool to cut a workpiece).
I obtained good ploughing/cutting phenomena when l use the setforce option of fix and setting a velocity for the tool to approach the workpiece, but l guess the cutting forces obtained are wrong. I used the following:
velocity tool set 1.0 0 0 sum yes units box
fix 6 tool setforce 0.0 0.0 0.0
Since l fixed the tool atoms to 0.0 (fx, fy, fz all set to zero), and l want to be able to evaluate the tool atoms forces l tried using :
fix 6 tool setforce NULL 0 NULL
to set fy to zero and obtain values for fx and fz (fy is to approx. zero in orthogonal cutting). This eventually didn’t work.
My use of addforce/aveforce didn’t help either.
Where could l be missing it out?
Thanks.
Jide
orthogonal cutting). This eventually didn't work.
My use of addforce/aveforce didn't help either.
the fix stores the total force on the atoms before they are overwritten.
you can access those as f_6[1], f_6[2], f_6[3] for example in thermo
output. for details see the lammps documentation about outputting
data from fixes.
cheers,
