I am trying to understand the code. I have some problem with the following part.
imagedata = ((imageint) IMGMAX << IMG2BITS) |
((imageint) IMGMAX << IMGBITS) | IMGMAX;
Since IMGMAX for 32-bit system is 512 isn’t imagedata always be 1?
Also what does this mean? I know that the imageflag is set by the set command to specify which image the atom in? I don’t understand the meaning of imagedata? What does this number mean? Also since this number is only 1? why should use imageint?
Thanks very much for your help?
Best!
Hao
following part.
it would be *extremely* helpful, if you'd also name the file and the
lines of the code that you are talking about.
Since IMGMAX for 32-bit system is 512 isn't imagedata always be 1?
not at all. for 32-bit imageint this evaluates to (512 << 20) | (512
<< 10) | 512 = 537395712 or 0x20080200
command to specify which image the atom in? I don't understand the meaning
with 32-bit ints for imageint, LAMMPS uses 10-bits to store image
information for x-, y-, and z (-512 to 512).
with the bitshifting, you can store all three 10-bit numbers in a
single integer.
so that when you compile with -DLAMMPS_BIGBIG, LAMMPS works correctly.
quite a lot of code that is contributed to LAMMPS is not 64-bit clean
and fails in these issues.
