I am having some asymmetric patchy particles and I want to achieve the function to allow them to only have the rotational movement and freeze the translation. That is to say, all the patchy particles are staying at where they are, but with random rotation so that the direction for patches is random. Is it possible in LAMMPS?
I assume there might be some fix command that might be able to achieve this but didn’t find it.
hard to say, how do you plan to represent these "patchy particles"?
Although LAMMPS does not have any direct command to eliminate translational motion of (center of mass) a non-rigid group of atoms (and leave them to rotate freely), you can still do it by the following procedure:
COM of a group of atoms (like Cu) doses not move in a direction (like x) if:
1- The net force exerted on them in that direction is zero (ΣFx=0)
2- The initial velocity of com the group in that direction is zero (V0x=0)
We should exert one small force on “each atom” in the group for either of these purposes.
1- A force to neutralize the effect of the force exerted by the surrounding which is the negative of:
compute fx_1 Cu reduce ave fx
2- A force to eliminate the translational momentum of the group in one timestep (F=-mV/dt) which is the negative of:
