OPTIMADE /v1/structures returns empty dataset (data_available=0) for all queries
Hi MP team,
We are seeing a consistent issue with the MP OPTIMADE endpoint in EMOS.
Date tested (UTC): 2026-07-29 15:13
Endpoint: https://optimade.materialsproject.org/v1/structures
Accept header: application/json
Observed behavior:
  • HTTP 200 responses
  • meta.data_available = 0
  • meta.data_returned = 0
  • data =
This occurs for:
  1. No filter:
    /v1/structures?page_limit=1
  2. HAS filter:
    /v1/structures?page_limit=1&filter=elements%20HAS%20%22Fe%22
  3. HAS ALL filter:
    /v1/structures?page_limit=1&filter=elements%20HAS%20ALL%20%22Fe%22
For comparison:
  • /v1/info still returns HTTP 200 with data_available=1 and data_returned=1.
Expected:
  • /v1/structures should return at least some records (or a clear maintenance/degraded message if temporarily unavailable).
Could you confirm whether this is a temporary index/data sync issue on the MP OPTIMADE service?
Thanks!
Hi @adixit ,
That’s odd, no major updates to our optimade service have occurred. Logs aren’t surfacing any errors currently either. Will take a deeper look and check back in
Hi @adixit,
Things should be back to normal now!
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
