Dear GULP developers and users,
I’m trying to perform optimisation and consequently calculate the phonons of a very large system, i.e. ~50.000 atoms. (It is so large because I’m investigating a disordered supercell of a molecular crystal.) I know such a calculation might well be near the limit of what is numerically feasible. However, by optimising my code I would like to test how large I can go.
As I understand it, GULP’s optimisation process is a balancing act between memory usage and computing time. I’m using the limited-memory BFGS algorithm, since loading the full Hessian causes my calculation to crash (if I’m correct this must be due to memory limits). I’m running my calculation in parallel on a HPC. I am currently running some tests to optimise two parameters:
- number of cores: the more cores, the faster the calculation (at least for a medium number of cores - it might taper off). However, the more cores I request, the longer my queuing time in the hpc.
- lbfgs order: the larger, the more memory is required, but the faster the convergence.
For the phonon calculation (full eigenvectors at Gamma point), as far as I know there’s no way to make it use less memory. But luckily by requesting a large number of cores I was able to run this calculation. So it is just the optimisation step I’m stuck at at the moment.
My question: I’d happily do the above described tests myself, but before I waste time on this: has anyone tried optimising such large systems before? Does anyone know what the quantitative relation is between system size, lbfgs order, memory usage and convergence speed? And are there any data available on GULP’s parallel performance in terms of speed versus number of cores (especially: when does the speed taper off?)?
Finally, any other suggestions or comments on how to solve this problem are also very welcome:)
Cheers,
Bernet
