Nope, still can’t post.
https://pastebin.com/uXpAuPny
Sidenote, Pastebin flagged it as potentially harmful…
Edit: I could only post it as private, I’m linking here instead.
LAMMPS (2 Aug 2023 - Development - patch_2Aug2023-427-g75682ffbca)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
package gpu 0
echo both
package gpu 1 omp 2 device_type nvidiagpu
variable temperature equal 100
variable tempDamp equal 2.5e-6
variable density equal 1e-6
variable particlessqrt equal 1000 # sqrt(number of particles)
variable seed equal 74581
variable thermo_out_freq equal 1000
variable dump_out_freq equal 500
variable time_step equal 5e-3
variable thermo_time equal 15e3
variable run_time equal 1e4
timer timeout 11:55:00 every 1000
New timer settings: style=normal mode=nosync timeout=11:55:00
dimension 2
units lj
atom_style atomic
# Create square lattice that becomes a gas upon equilibration at high temperature
lattice sq ${density}
lattice sq 1e-06
Lattice spacing in x,y,z = 1000 1000 1000
region box block 0 ${particlessqrt} 0 ${particlessqrt} -0.1 0.1
region box block 0 1000 0 ${particlessqrt} -0.1 0.1
region box block 0 1000 0 1000 -0.1 0.1
create_box 1 box
Created orthogonal box = (0 0 -100) to (1000000 1000000 100)
5 by 2 by 1 MPI processor grid
create_atoms 1 box
Created 1000000 atoms
using lattice units in orthogonal box = (0 0 -100) to (1000000 1000000 100)
create_atoms CPU = 0.029 seconds
pair_style lj/cut/gpu 2.5
pair_coeff * * 1.0 1.0 2.5
mass 1 1.0
thermo ${thermo_out_freq}
thermo 1000
timestep ${time_step}
timestep 0.005
# default time step is 5e-3
neighbor 500.0 bin
# Equilibrate
fix 1 all nvt/gpu temp ${temperature} ${temperature} $(285.0*dt)
fix 1 all nvt/gpu temp 100 ${temperature} $(285.0*dt)
fix 1 all nvt/gpu temp 100 100 $(285.0*dt)
fix 1 all nvt/gpu temp 100 100 1.4250000000000000444
#fix 2 all momentum 10000 linear 1 1 1 angular
fix 3 all enforce2d
velocity all create ${temperature} ${seed} dist gaussian
velocity all create 100 ${seed} dist gaussian
velocity all create 100 74581 dist gaussian
variable fx atom sin(2*PI*y*${density})*sqrt(${temperature})/100/(${thermo_time}*${time_step})
variable fx atom sin(2*PI*y*1e-06)*sqrt(${temperature})/100/(${thermo_time}*${time_step})
variable fx atom sin(2*PI*y*1e-06)*sqrt(100)/100/(${thermo_time}*${time_step})
variable fx atom sin(2*PI*y*1e-06)*sqrt(100)/100/(15000*${time_step})
variable fx atom sin(2*PI*y*1e-06)*sqrt(100)/100/(15000*0.005)
fix 4 all addforce v_fx 0. 0.
run ${thermo_time}
run 15000
CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE-CITE
Your simulation uses code contributions which should be cited:
- GPU package (short-range, long-range and three-body potentials): doi:10.1016/j.cpc.2010.12.021, doi:10.1016/j.cpc.2011.10.012, doi:10.1016/j.cpc.2013.08.002, doi:10.1016/j.commatsci.2014.10.068, doi:10.1016/j.cpc.2016.10.020, doi:10.3233/APC200086
@Article{Brown11,
author = {W. M. Brown and P. Wang and S. J. Plimpton and A. N. Tharrington},
title = {Implementing Molecular Dynamics on Hybrid High Performance Computers---Short Range Forces},
journal = {Comput.\ Phys.\ Commun.},
year = 2011,
volume = 182,
pages = {898--911},
doi = {10.1016/j.cpc.2010.12.021}
@Article{Brown12,
author = {W. M. Brown and A. Kohlmeyer and S. J. Plimpton and A. N. Tharrington},
title = {Implementing Molecular Dynamics on Hybrid High Performance Computers - Particle-Particle Particle-Mesh},
year = 2012,
volume = 183,
doi = {10.1016/j.cpc.2011.10.012},
pages = {449--459}
@Article{Brown13,
author = {W. M. Brown and Y. Masako},
title = {Implementing Molecular Dynamics on Hybrid High Performance Computers---Three-Body Potentials},
year = 2013,
volume = 184,
pages = {2785--2793},
doi = {10.1016/j.cpc.2013.08.002},
@Article{Trung15,
author = {T. D. Nguyen and S. J. Plimpton},
title = {Accelerating Dissipative Particle Dynamics Simulations for Soft Matter Systems},
journal = {Comput.\ Mater.\ Sci.},
year = 2015,
doi = {10.1016/j.commatsci.2014.10.068},
volume = 100,
pages = {173--180}
@Article{Trung17,
author = {T. D. Nguyen},
title = {{GPU}-Accelerated {T}ersoff Potentials for Massively Parallel
Molecular Dynamics Simulations},
year = 2017,
doi = {10.1016/j.cpc.2016.10.020},
volume = 212,
pages = {113--122}
@inproceedings{Nikolskiy19,
author = {V. Nikolskiy and V. Stegailov},
title = {{GPU} Acceleration of Four-Site Water Models in {LAMMPS}},
booktitle = {Proceedings of the International Conference on Parallel
Computing (ParCo 2019), Prague, Czech Republic},
doi = {10.3233/APC200086},
year = 2019
Generated 0 of 0 mixed pair_coeff terms from geometric mixing rule
Per MPI rank memory allocation (min/avg/max) = 28.16 | 28.16 | 28.16 Mbytes
Step Temp E_pair E_mol TotEng Press
0 100 0 0 99.9999 9.99999e-05
1000 100.00008 0 0 99.999982 9.9999982e-05
2000 100.00038 0 0 100.00028 0.00010000028
3000 99.997519 0 0 99.997419 9.9997419e-05
4000 100.01986 0 0 100.01976 0.00010001976
5000 99.989808 3.3399417e-06 0 99.989711 9.9989747e-05
6000 99.843516 -1.044226e-06 0 99.843415 9.9843416e-05
7000 100.0019 -4.3974058e-07 0 100.0018 0.0001000018
8000 100.25663 3.203424e-05 0 100.25657 0.00010025677
9000 100.0668 -1.4849451e-06 0 100.0667 0.0001000667
10000 99.944044 -1.0559888e-06 0 99.943943 9.9943942e-05
11000 99.964048 3.5635778e-06 0 99.963952 9.9963991e-05
12000 99.988759 -1.9086447e-06 0 99.988657 9.9988654e-05
13000 100.10312 6.0832521e-08 0 100.10302 0.00010010304
14000 100.0813 1.838889e-05 0 100.08121 0.00010008135
15000 100.10201 -1.4708056e-06 0 100.10191 0.00010010191
Loop time of 422.865 on 20 procs for 15000 steps with 1000000 atoms
Performance: 15324.036 tau/day, 35.472 timesteps/s, 35.472 Matom-step/s
197.5% CPU use with 10 MPI tasks x 2 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 92.415 | 98.635 | 103.16 | 37.7 | 23.33
Neigh | 0.060491 | 0.07019 | 0.079606 | 1.9 | 0.02
Comm | 21.621 | 22.472 | 23.17 | 11.6 | 5.31
Output | 0.032442 | 0.034114 | 0.035846 | 0.5 | 0.01
Modify | 255.22 | 264.43 | 272.32 | 33.7 | 62.53
Other | | 37.22 | | | 8.80
Nlocal: 100000 ave 100034 max 99976 min
Histogram: 1 1 1 4 0 0 2 0 0 1
Nghost: 701.6 ave 727 max 673 min
Histogram: 2 1 1 0 0 0 2 1 1 2
Neighs: 0 ave 0 max 0 min
Histogram: 10 0 0 0 0 0 0 0 0 0
Total # of neighbors = 0
Ave neighs/atom = 0
Neighbor list builds = 67
Dangerous builds = 0
reset_timestep 0
# Production
unfix 1
#unfix 2
unfix 4
fix 5 all print 100 "$(step) $(temp) $(pe) $(ke) $(press) $(density)" file thermo.txt title "# step temp pe ke press density" screen no
fix 6 all nve/gpu
#dump myDump all atom ${dump_out_freq} pablo_lj.pos
#dump myDump2 all custom ${dump_out_freq} pablo_lj.vel id vx vy
#run 1000000
dump myDump all atom ${dump_out_freq} pablo_lj_short.pos
dump myDump all atom 500 pablo_lj_short.pos
#dump myDump2 all custom ${dump_out_freq} pablo_lj_short.vel id vx vy
dump myDump3 all custom ${dump_out_freq} particles.data id x y vx vy
dump myDump3 all custom 500 particles.data id x y vx vy
run ${run_time}
run 10000
Per MPI rank memory allocation (min/avg/max) = 24.22 | 24.23 | 24.23 Mbytes
1000 103.79139 -1.3592123e-06 0 103.79128 0.00010379128
2000 103.84707 -3.7718733e-07 0 103.84696 0.00010384696
3000 103.85145 1.0619734e-05 0 103.85136 0.00010385145
4000 103.86236 1.8307881e-06 0 103.86226 0.0001038623
5000 103.88417 1.3530946e-05 0 103.88408 0.00010388419
6000 103.90217 -1.0495417e-06 0 103.90207 0.00010390207
7000 104.03153 -1.2831594e-06 0 104.03143 0.00010403143
8000 104.06044 1.0778544e-05 0 104.06035 0.00010406043
9000 104.08473 -1.9532786e-06 0 104.08462 0.00010408463
10000 104.08981 -3.01135e-06 0 104.0897 0.00010408971
Loop time of 135.218 on 20 procs for 10000 steps with 1000000 atoms
Performance: 31948.480 tau/day, 73.955 timesteps/s, 73.955 Matom-step/s
195.2% CPU use with 10 MPI tasks x 2 OpenMP threads
Pair | 45.86 | 47.607 | 50.611 | 23.3 | 35.21
Neigh | 0.37639 | 0.39791 | 0.42449 | 2.6 | 0.29
Comm | 16.843 | 17.826 | 18.493 | 12.0 | 13.18
Output | 5.7644 | 6.3837 | 6.9683 | 15.4 | 4.72
Modify | 26.222 | 28.519 | 30.203 | 24.6 | 21.09
Other | | 34.48 | | | 25.50
Nlocal: 100000 ave 100022 max 99969 min
Histogram: 1 0 1 1 1 0 1 2 1 2
Nghost: 707.7 ave 738 max 664 min
Histogram: 1 0 0 1 2 0 3 0 2 1
Ave neighs/atom = 0
Neighbor list builds = 379
write_data lj.lammps-data
System init for write_data ...
Total wall time: 0:09:25
