OSError: [Errno 2] No such file or directory
Dear All,
When I ran the test workflow on https://hackingmaterials.github.io/atomate/installation.html#introduction, my job is fizzled. I checked FW_job-516787.error and found the error below
File “/gpfs0/shared/apps/util/easybuild/software/FireWorks/1.4.3-intel-2017a-Python-2.7.13/lib/python2.7/site-packages/FireWorks-1.4.3-py2.7.egg/fireworks/core/rocket.py”, line 230, in run
m_action = t.run_task(my_spec)
File “/opt/apps/util/easybuild/software/atomate/0.4.5-intel-2017a-Python-2.7.13/lib/python2.7/site-packages/atomate-0.4.5-py2.7.egg/atomate/vasp/firetasks/run_calc.py”, line 185, in run_task
c.run()
File “/gpfs0/shared/apps/util/easybuild/software/custodian/1.1.0-intel-2017a-Python-2.7.13/lib/python2.7/site-packages/custodian-1.1.0-py2.7.egg/custodian/custodian.py”, line 313, in run
self._run_job(job_n, job)
File “/gpfs0/shared/apps/util/easybuild/software/custodian/1.1.0-intel-2017a-Python-2.7.13/lib/python2.7/site-packages/custodian-1.1.0-py2.7.egg/custodian/custodian.py”, line 362, in _run_job
p = job.run()
File “/gpfs0/shared/apps/util/easybuild/software/custodian/1.1.0-intel-2017a-Python-2.7.13/lib/python2.7/site-packages/custodian-1.1.0-py2.7.egg/custodian/vasp/jobs.py”, line 198, in run
p = subprocess.Popen(cmd, stdout=f_std, stderr=f_err)
File “/opt/apps/util/easybuild/software/Python/2.7.13-intel-2017a/lib/python2.7/subprocess.py”, line 390, in init
errread, errwrite)
File “/opt/apps/util/easybuild/software/Python/2.7.13-intel-2017a/lib/python2.7/subprocess.py”, line 1024, in _execute_child
raise child_exception
INFO:rocket.launcher:Rocket finished
Anybody has ideas on this error?
Thanks in advance!
Yang Tong
Hi Yang
1 - please check the font size on your help requests, it is difficult to read such large font
2 - most likely, your “vasp_cmd” is not set correctly. Please check your my_fworker.yaml file here: Installing atomate — atomate 1.0.3 documentation
and also make sure that you can run that command on the computer where you are executing your workflows
If you still have issues, please email the list again and include some more details such as:
  • where are you running the job
  • what does your my_fworker.yaml look like
  • the full contents of the the Firework you are trying to run. You can get this using “lpad get_fws -i <FW_ID> -d all”.
Anubhav
On Saturday, February 10, 2018 at 5:03:47 AM UTC-8, Tong Yang wrote:
Dear All,
c.run()
p = job.run()
errread, errwrite)
Thanks in advance!
Yang Tong
