Hello! In versions 3.10.2 and .3, the “Pick in viewport” function doesn’t pick the focal point from the viewport if the OSPRay render is selected. It works fine for Tachyon.
Tested on Debian Linux 6.1.0-17-amd64.
Thank you, Otello. This issue will be fixed in the next release. A subtle C++ ODR violation was responsible for it.
Hi Alex, brilliant as usual!
Is this the preferred place to submit bug reports?
Opening a GitLab issue is the preferred way of reporting a bug, because this makes tracking the issue easier. But you are welcome to report issues in any way you want.
