Hi everyone,
I am doing a cluster analysis in OVITO and I am looking at clusters with a size of 3. I export the cluster analysis data as .xyz in order to further analyse them and separate H2O from other clusters with 3 atoms (SiO2, HO2 etc.), but also because I want the atom velocities. When I save the data though it also saves all other clusters with different sizes.
Is there a way to only select and export clusters with a certain size, either using a modifier of a python script?
Anastasis
Yes, In OVITO Pro, you can use a Python script modifier to look up the Cluster identifiers for all Clusters with a size of 3 in the Cluster list data table generated by the Cluster analysis modifier. This information can then be used to filter and remove all particles from the scene that do not correspond to the identified Cluster particle property values, e.g.,
cluster_ids = data.tables['clusters']['Cluster Identifier'][data.tables['clusters']['Cluster Size'] == 3]
Please don’t hesitate to contact OVITO Pro support via email if you need additional assistance with developing your code.
Hey @kalcher,
What about getting the atoms ids building up the clusters ?
Thank you in advance.
Anouar
The Cluster Analysis modifier creates a new integer particle property name “Cluster”, which tells you the cluster each atom has been assigned.
# List of atom IDs (one entry per particle)
data.particles["Particle Identifier"]
# List of cluster IDs (one entry per particle)
data.particles["Cluster"]
# Combine both into a table, i.e., pairs of atom ID and cluster ID
numpy.vstack((data.particles["Particle Identifier"], data.particles["Cluster"]))
# Use NumPy indexing to get the list of atom IDs belonging to cluster i
i = 1
data.particles["Particle Identifier"][data.particles["Cluster"] == i]
