Dear Sir/Madam,
I’m using fix langevin to thermostat a slab of 3C-SiC with its (111) surface facing to the vacuum. I set the fix commands as:
fix 1 all nve
fix lange all langevin 300.0 300.0 0.025 598043 tally yes
I run the system for 1 ns, and output the return scalar of fix langevin (f_lange). I found that the value of f_lange is always increasing linearly throughout the simulation (from zero to about 50 eV). Is this normal? I think f_lange should stay constant after the system reaches the equilibrium since no energy is added in or removed from the system, right?
I appreciate your help!
thanks,
Jibao
Dear Sir/Madam,
fix 1 all nve
for that to be true, you have to have a simulation that conserves energy sufficiently well, when running with fix nve alone without fix langevin after the system is sufficiently well equilibrated. a thermostat can hide this, and your observation suggests, that this may be the case here.
Dear Axel,
I got it. Thanks for the tip!
Jibao
