Dear all
I am running simulation of 5120 Ni atoms doped with Fe, I have used the compute command to compute the bond orientation order by using the “compute orientorder/atom” but am unable to dump it using the dump custom command I am including the log for the input file and the error. Is there any other way for getting the output of this per atom without the use of user packages. Does it Depend on the file type?
Thank you
units real
atom_style atomic
#log log.$rsimname}.txt
read_data ni3fe.txt
pair_style eam/alloy
pair_coeff * * NiFe.set Ni Fe
neighbor 1.0 bin
neigh_modify every 1 delay 5 check yes
#Equilibration
velocity all create 300.0 492825 dist gaussian
timestep 1
thermo 1000
thermo_style multi
fix 1 all nvt temp 300.0 300.0 100.0
compute myBond all orientorder/atom degrees 2 4 6
compute myRDF all rdf 100 1 1 1 2 2 1 2 2
fix 3 all ave/time 100 10 5000 c_myRDF file tmp.rdf mode vector
dump 1 all xyz 5000 300_MC_swap_MD_ni3fe.xyz
dump 2 all custom 1000000 dump.123.xyz id type c_myBond
restart 1000000 ni3fe1.restart
run 5000000
ERROR: Dump custom compute does not calculate per-atom vector (…/dump_custom.cpp:1228)
PS: I have also included the text file for my initial configuration to be used in the input file
Joydeep Datta
Indian Institute of Technology, Kanpur
ni3fe.txt (211 KB)
