My system contains a water droplet and a solid substrate. How can I get the forces between the water molecules (not include the forces between the solid atoms and the water molecules)
I think you probably can divide water into two groups.
And use compute group/group command to get the forces between water molecules.
If anyone has a better solution?
Dezhao Huang, Ph.D. student
University of Notre Dame
Department of Aerospace and Mechanical engineering
molecules.
the request was not very well formulated, so it is not really possible to
provide a definite response.
typically, the most general approach to decompose forces into
contributions from different parts of the system, is to simulate a
trajectory with all interactions included. and then use the rerun command
to post-process that trajectory with only the interactions of interest
configured and everything else set to zero. notabene, for systems with
long-range coulomb via a kspace style, also partial charges need to be
overridden, or else the long-range terms will include contributions from
otherwise excluded atoms.
