Problem is the information I would like to output " total simulated time
i.e. actual time " is not listed.
e.g. if I run 1000 steps with dt = 5e-4 and then 1000 runs with dt = 2000
runs then, I should out put 1000*5e-4 + 2000*5e-3 at the end.
since you already know this when you start the script, what keeps you
from computing it yourself?
Also at the thermo_style the output provided does not allow total simulation
time.
I hope I have clearified the question ?
not really. you didn't say what you have already tried and what didn't
work as expected?
also, what keeps you from accumulating this information using some
equal style variable and taking advantage of the fact that ${name} is
expanded when the variable is defined while v_name will be expanded
every time the variable is referenced.
What I am trying to do (at the end) is to write a plot of energy vs time, but the problem is that I can have several runs with a change of timestep in between.
Eventually I would like to write the simulation time in the dump file instead of timestep, too.
For sure that I can do it manually, but is very difficult if you are modifying the number of runs or changing values in the script.
I have tried save in a variable the cumulative value of step*dt after each run
I’m just trying to do something similar to elaplong, but with the simulation time.
Just added a “time” keyword to thermo_style custom
which should do what you want. I realized this value is
easy to output without updating it internally every timestep.
Should work with fix dt/reset and resetting the timestep
as well.
