Hi There,
We tried to compile lammps with cuda, but get the following error:
/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp(12): error: function “min(unsigned long, unsigned long)” has already been defined
/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp(17): error: function “max(unsigned long, unsigned long)” has already been defined
/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp(68): error: more than one instance of overloaded function “min” matches the argument list:
function “min(unsigned int, unsigned int)”
function “min(int, unsigned int)”
function “min(unsigned long, long)”
argument types are: (size_t, const unsigned int)
/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp(83): warning: integer conversion resulted in a change of sign
/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp(88): warning: integer conversion resulted in a change of sign
/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp(93): warning: integer conversion resulted in a change of sign
3 errors detected in the compilation of “/tmp/tmpxft_0001663b_00000000-6_cudpp_maximal_launch.cpp1.ii”.
make[2]: *** [CMakeFiles/gpu.dir/scratch/jzhang8/LAMMPS/lammps/lib/gpu/cudpp_mini/cudpp_maximal_launch.cpp.o] Error 1
make[1]: *** [CMakeFiles/gpu.dir/all] Error 2
make: *** [all] Error 2
The Lammp I downloaded was from git. Compiled with CUDA version is 9.2.148.1 and intel 2017.u2 and Open MPI-3.0.0
Any help will be appreciated.
Cheers
Jin
