Dear Ray!
I accidentally discovered that:
In reaxc_defs.h:
#define DANGER_ZONE 0.90
#define LOOSE_ZONE 0.75
But in fix_qeq_reax.cpp:
#define DANGER_ZONE 0.95
Is it right or not?
Regards,
Vitaly
Dear Ray!
In reaxc_defs.h:
Is it right or not?
Regards,
Vitaly
Hi Vitaly,
Rigorously speaking they should be removed, and the above “EV_TO_KCAL_PER_MOL” should be changed to “force->qqr2e” to be consistent with LAMMPS. These changes may be sent in to be included in patches, but they are fine as they are now.
Ray
Hi Vitaly,
After examining the fix qeq/reax routine more carefully, re-defining DANGER_ZONE, LOOSE_ZONE and MIN_NBRS are actually necessary. This is because fix qeq/reax can be used independently from pair reax/c with other pair styles to perform charge equilibration. If USER-REAXC is not installed, fix qeq/reax will not know anything about these values. Nevertheless, the values should be kept the same.
Ray
