First of all, thanks a lot for developing fireworks and making it publicly available.
The documentation (e.g. https://materialsproject.github.io/fireworks/queue_tutorial_pt2.html) mentions that it is possible to override the default parameters of the queue_adapter, by using the _queue_adapter keyword in spec.
I’ve had no problems modifying parameters such as walltime in this way. However, when I tried to modify the _fw_template_file, it did not seem to have any impact. Here is how I was trying to do it:
fw = Firework( [firetask1, firetask2, firetask3], name=name,
spec={'_queueadapter':
{'_fw_template_file': '/absolute/path/to/template/file' })
launchpad.add_wf(fw)
Any advice on the above? Is this feature simply not supported, or did I do something wrong in the way I am using it?
Hi Remi,
The “_qadapter” overrides are really for overriding the parameters in the template file rather than changing the queueadapter that gets loaded. The underscore for “_fw_template_file” is intended to indicate that this an internal variable controlling which QueueAdapter class gets loaded and with what template file.
What you can change with “_qadapter” overrides are all the variables inside the template files like those in: fireworks/user_objects/queue_adapters/SLURM_template.txt
That said, I am not quite sure why you would want the firework itself to decide which template file to use. Usually, the choice of template (e.g., whether to use a SLURM template or a PBS template) would depend on the machine you are running on rather than the firework that is getting run.
Could you explain a little more about the functionality you are trying to achieve? We might be able to advise on how to best get there.
Btw, if you are around LBNL, I and many of the other FWs developers are in 33-306 today (apart from lunch hours) doing mostly programming work in case you want to stop by and ask any questions in person.
Anubhav
