Hi All,
I am trying to run multiple simulations, but I am overwriting dump files which are supposed to be created at each different run and only having the dump file of last run. Below one is the input file:
variable a loop 9
variable seed index 1 2 3 4 5 6 7 8 9
log log.$a
variable sigma equal 2.498896133
variable vx equal normal(0,\{sigma\},{seed})
variable vy equal normal(0,\{sigma\},{seed})
variable vz equal normal(0,\{sigma\},{seed})
velocity mobile set \{vx\} {vy} ${vz}
print "vz = ${vz}"
if "vz < 0" then quit
dump 1 mobile custom 100 Ar_Velocity_Position.dat id vx vy vz x y z
thermo 10
run 100
clear
next seed
next a
jump in.automation_501
1-) What should I do not to overwrite the dump files
2-) Why the printed vz value and the real value of Vz are different from each other?
velocity mobile set \{vx\} {vy} \{vz\}
velocity mobile set \-3\.16470773391865 {vy} \{vz\}
velocity mobile set \-3\.16470773391865 2\.95503089942291 {vz}
velocity mobile set -3.16470773391865 2.95503089942291 -1.42000795332037
print "vz = ${vz}"
vz = 1.4577597271259
I will appreciate your help.
Rose
