OVITO 3.12 is now available!
OVITO Basic 3.12 and OVITO Pro 3.12 are now available! You can download the new version from our website. Here are some highlights from this release. For full details, please see the changelog .
OVITO Pro as a Jupyter kernel
Combining interactive Python scripting with the full OVITO Pro GUI to directly visualize pipelines defined in your notebook:
Highlight molecules and atoms using outlines
A new depth-aware outline effect is available in OSPRay renderer and VisRTX renderer:
Expression selection
You can now use type names in the expression selection modifier:
Compute property modifier
Compute property modifier can now include neighbors based on bonds instead of distance in the calculation:
Python extensions
A new streamlined interface to install and manage Python extensions. Discover and install third-party extensions right from the OVITO Pro Python extension gallery:
Or add any Python package into the embedded Python interpreter from the settings menu:
Full changelog…
After updating to 3.12, I came across an issue ( I think that’s an issue):
When I open one file, it will look like:
And When I click anywhere or do anything with my mouse, it will look normally:
Could you pls check if it’s a bug or not? I copied the system info from OVITO for your reference (Actually the operating system should be Win11):
======= System info =======
Current date: Fri Mar 7 14:13:39 2025
Application: OVITO Basic 3.12.0
Operating system: Windows (10.0)
Processor architecture: x86_64
Qt version: 6.7.3 (x86_64)
Command line: D:\ProgramInstall\OVITO Basic\ovito.exe C:\Users\Sailang\Desktop\AgPt\lammpsdata.rawPtAg
Python file path: D:/ProgramInstall/OVITO Basic/plugins/python
CUDA support enabled: yes
======= CUDA info =======
No CUDA-capable device detected
======= OpenGL info =======
Vendor: ATI Technologies Inc.
Renderer: AMD RadeonT 780M
Version number: 4.6
Version string: 4.6.0 Compatibility Profile Context 24.10.39.05.241016
Profile: compatibility
Swap behavior: double buffer
Depth buffer size: 24
Stencil buffer size: 8
Shading language: 4.60
Deprecated functions: yes
Geometry shader support: yes
Alpha: 1
Fan
Thank you for this report. This looks like a bug. Just to confirm, this happens with all files you load, or just specific ones? And once you interact with the program the visuals go back to normal?
sorry for the delay to reply. For youe reference:
  1. I tested several files and the issue always happened.
  2. Yes, it would be normal when I did any interaction.
Now I go back to an older OVITO version and the issue doesn’t happen, therefore it’s quite possible that it’s a bug.
BR
Thank you for the update. We had 2 or 3 reports of this bug. So it appears to be quite rare but we’re investigating the issue. I’ll let you know once we know more.
I’m unable to reproduce this issue locally, so it appears to be quite system-specific. I’ve prepared an update that will hopefully resolve the problem. You can find the development versions here:
old links removed
It would be great if you could test them on your system and let me know if this resolves the error.
