Dear Lammps users,
I upgraded my workstation with the new Linux CentOS6.
On my old workstation (CentOS 5.5) I had a lammps parallel version okay
working but with the new one I am not able to have it working again.
I am trying to build the latest version of lammps with openmpi and g++.
I am doing everything exactly as I did in the past:
- I compile the library of all the additional packages successfully
- I make lammps with all the the packages apart from the gpu and the atc
- I make lammps with a makefile I edited well tailored at my system
I attach hereby a file with the last lines of the output generated when
I try to make lammps (make.output). The error I get is shown in the
subject of this e-mail.
I attach also the makefile I am using (Makefile.pf3). Maybe it can be
useful to some user.
The make file worked well with my old workstation.
The only change I did in the makefile is the path of the openmpi. The
path of the header changed with the new version of openmpi.
The compilation process starts correctly, so I am here asking help, if
you can. I truly hope you can.
All the best,
Alessandro Corozzi
Office: +4545252058
e-mail: [email protected]
Kemitorvet #201, Room #154
2800 Kgs. Lyngby
Danmark (Dk)
make.output (20.3 KB)
Makefile.pf3 (819 Bytes)
