pair/local granular
I have a problem damping the result of compute pair/local in granular simulations (13Apr17)
For instance, to output the distances between the interacting particles, I use following lines:
#### lines added
compute c1 all pair/local dist
dump  dump_local all local 1 Distances.dat c_c1
dump_modify dump_local first no
run 1
undump dump_local
uncompute c1
I added these lines at the end of few example files, e.g. "in.min", and the result is as expected.
If, however, I add them at the end of the example file "in.pour", the dump file only contains the standard header lines, as if there were no interacting particles.
The same occurs if a try to output the result of a compute property/local.
Any suggestion?
Many thanks!
Massimo
#### lines added
run 1
undump dump_local
uncompute c1
Any suggestion?
​i cannot reproduce it with either the latest stable (11 Aug 2017) or the
latest patch ​(23 Oct 2017) version.
[[email protected]... lammps]$ head -20 Distances.dat
ITEM: TIMESTEP
50000
ITEM: NUMBER OF ENTRIES
2639
ITEM: BOX BOUNDS pp pp fm
-10 10
-10 10
-0.5 16
ITEM: ENTRIES c_c1
0.999591
0.995529
0.999852
0.995543
0.997128
0.999987
0.997502
0.999719
0.999555
0.998908
0.998866
