Dear lammps users,
I wanted to ask, mostly to the developer of the soft-core version of the potentials. On the documentation is said that soft potentials supports mixing with pair modify, however then is not possible to use the fix/adapt fep or compute fep regarding the mixed interaction right? The interaction coefficient must be explicetely imposed in the script?
for instance
pair_style hybrid lj/cut/coul/long/soft 1 0.5 10 15.0 10.0 etc
pair_coeff 1 1 lj/cut/coul/long/soft 0.5 3 1.0
pair_coeff 2 2 lj/cut/coul/long/soft 0.6 3.1 1.0
pair_modify pair lj/cut/coul/long/soft mix geometric
fix adapt all adapt fep {Nadapt} pair lj/cut/coul/long/soft lambda 1 2 v_lambda
compute FEP all fep {Temp} pair lj/cut/coul/long/soft lambda 1 2 v_lambda
It will not act since pair_coeff 1 2 is not explicitely reported? If someone knows this for sure i would like to have confirmation
Kind regards,
Lorenzo Chiavarini
In order to adapt the parameters for the unlike interactions you need to supply all pairs explicitly and not use pair_modify mix.
Cheers,
Agilio
Yeah, my problem was that I have a complex organic molecule which interacts with water, therefore I generate the coeff from Opslaa and i have 820 pair coeffs, so i can’t write them explicitly.
I also tried to use hybrid/overlay and define more pair styles like:
pair_style hybrid/overlay lj/cut …… lj/cut/coul/long …… lj/cut/coul/long/soft
pair_coeff 1 1 lj/cut 0.0 1.0
Pair_coeff 820 820 lj/cut 0.0 1.0
And then define the one I’m interested by hand while using:
pair_modify lj/cut mix arithmetic
but it says that not all pair coeffs are set. I do not understand why it says so since the mixing should work only on that pair_style also no?
Kind regards,
Lorenzo
Here is what i wanted to do but seems not to be allowed by pair_modify…
in_singlelayer_mixing2.gro2lam (35 KB)
Why not? A script can go through the like pairs and generate the unlike parameters. This can be put in its own file and then read into your input file using the include command.
I find impressive that you have 820 atom types in terms of the pair potential. Partial charges do vary a lot for the same element in different molecules/chemical environments but the LJ parameters vary much less.
pair_style hybrid/overlay lj/cut ….. lj/cut/coul/long ….. lj/cut/coul/long/soft
Mixing mix
with overlay has its peculiarities. See the doc page of pair_style hybrid/overlay.
Agilio
