I am trying to use hybrid/overlay pair_style with lj/charmmfsw/coul/long and hdnnp potentials. The system has 10 atom types and the hdnnp is used for the interaction between the last two (for which the model is trained). However, when I try to run the setup I get the following error:
Element mapping string from LAMMPS to n2p2: ",9:H,10:O"
terminate called after throwing an instance of 'std::runtime_error'
what(): ERROR: Element mapping is inconsistent, NNP elements: 2, emap elements: 3.
Please, can you help me, what am I doing wrong?
Or is it a bug? It looks the same as the bug in this post: Support of multiple pair styles via hybrid/overlay in lammps interface · Issue #29 · CompPhysVienna/n2p2 · GitHub
I used the 2 August 2023 LAMMPS version. The setup file looks like:
variable T equal 300.0
variable tau_T equal 100.0
variable p equal 1.0
variable tau_p equal 1000.0
variable s_thermo equal 10000
variable steps equal 2000000
units real
neighbor 1.0 bin
atom_style full
bond_style harmonic
improper_style harmonic
angle_style charmm
dihedral_style charmm
special_bonds charmm
pair_style hybrid/overlay lj/charmmfsw/coul/long 8 10 &
hdnnp 6.36 dir "../nnp" cflength 1.8897259 cfenergy 0.0015936
read_data system.data
pair_coeff 1 1 lj/charmmfsw/coul/long 0.12 2.43572
pair_coeff 2 2 lj/charmmfsw/coul/long 0.15 4.04468
pair_coeff 3 3 lj/charmmfsw/coul/long 0.024 2.38761
pair_coeff 4 4 lj/charmmfsw/coul/long 0.046 0.400014
pair_coeff 5 5 lj/charmmfsw/coul/long 0.11 3.56359
pair_coeff 6 6 lj/charmmfsw/coul/long 0.01 3.38542
pair_coeff 7 7 lj/charmmfsw/coul/long 0.2 2.76179
pair_coeff 8 8 lj/charmmfsw/coul/long 0.12 2.49452
pair_coeff 1 9 lj/charmmfsw/coul/long 0.074 1.417867
pair_coeff 2 9 lj/charmmfsw/coul/long 0.083 2.222347
pair_coeff 3 9 lj/charmmfsw/coul/long 0.083 1.393812
pair_coeff 4 9 lj/charmmfsw/coul/long 0.046 0.400014
pair_coeff 5 9 lj/charmmfsw/coul/long 0.071 1.981802
pair_coeff 6 9 lj/charmmfsw/coul/long 0.021 1.892717
pair_coeff 7 9 lj/charmmfsw/coul/long 0.021 1.580902
pair_coeff 8 9 lj/charmmfsw/coul/long 0.021 1.580902
pair_coeff 1 10 lj/charmmfsw/coul/long 0.135 2.793145
pair_coeff 2 10 lj/charmmfsw/coul/long 0.151 3.597625
pair_coeff 3 10 lj/charmmfsw/coul/long 0.060 2.76909
pair_coeff 4 10 lj/charmmfsw/coul/long 0.0836 1.775292
pair_coeff 5 10 lj/charmmfsw/coul/long 0.129 3.35708
pair_coeff 6 10 lj/charmmfsw/coul/long 0.039 3.267995
pair_coeff 7 10 lj/charmmfsw/coul/long 0.174 2.95618
pair_coeff 8 10 lj/charmmfsw/coul/long 0.135 2.822545
pair_coeff * * hdnnp NULL NULL NULL NULL NULL NULL NULL NULL H O
pair_modify mix arithmetic
kspace_style ewald 1e-6
thermo ${s_thermo}
thermo_style multi
timestep 0.5
fix npt all npt temp ${T} ${T} ${tau_T} tchain 3 iso ${p} ${p} ${tau_p} mtk yes
velocity all create ${T} 42 dist gaussian
run ${steps}
Thank you,
Pavol
