Hi all. I am trying to simulate a Cu-Zr-O metallic glass using an EAM potential for interaction between Cu and Zr atoms and the comb3 potential for interactions with O. Please refer to the input script below. I am unsure if I am implementing the comb3 potential correctly since I haven’t used it before.
units metal # Angstrom, eV, ps, bar
boundary p p p # Periodic boundaries in all dimensions.
atom_style charge # Pair potentials.
newton on
Input data
read_data Zr50Cu50_50K_small
set type 1 type/fraction 3 0.02 4647
set type 2 type/fraction 3 0.02 5746
mass 1 91.2
mass 2 63.5
mass 3 16.0
Define interatomic potential.
pair_style hybrid comb3 polar_off eam/alloy
pair_coeff * * comb3 ffield.comb3 Zr Cu O
pair_coeff * * eam/alloy ZrCu.lammps.eam Zr Cu NULL
neighbor 2.0 bin
Set up thermo.
thermo 1000
thermo_style custom step temp lx ly lz press pxx pyy pzz pe etotal enthalpy vol density
thermo_modify norm yes flush yes
Set up charge equilibration.
fix 1 all qeq/comb 1 0.0001
Minimize input structure.
minimize 1.0e-4 1.0e-6 1000 10000
Initialize velocity and equilibrate in NVE.
fix 2 all nve
timestep 0.0005
velocity all create 50 4928459 mom yes rot yes dist gaussian
run 100000
unfix 2
Every time I run this script, I get non-numeric pressure and energies and lammps says there is a segmentation fault. Please refer to the output below.
LAMMPS (29 Oct 2020)
Reading data file …
orthogonal box = (1.0918818 1.0918818 1.0918818) to (53.308118 53.308118 53.308118)
4 by 4 by 5 MPI processor grid
reading atoms …
8192 atoms
read_data CPU = 0.015 seconds
Setting atom values …
85 settings made for type/fraction
92 settings made for type/fraction
PairComb3: polarization is off
Reading COMB3 potential file ffield.comb3 with DATE: 2015-09-18
element[1] = Zr, z = 1.83153
element[2] = Cu, z = 1.39726
element[3] = O , z = 1.37179
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 13
ghost atom cutoff = 13
binsize = 6.5, bins = 9 9 9
4 neighbor lists, perpetual/occasional/extra = 4 0 0
(1) pair comb3, perpetual, skip from (3)
attributes: full, newton on, ghost
pair build: skip/ghost
stencil: none
bin: none
(2) pair eam/alloy, perpetual, skip from (4)
attributes: half, newton on
pair build: skip
stencil: none
bin: none
(3) neighbor class addition, perpetual
pair build: full/bin/ghost
stencil: full/ghost/bin/3d
bin: standard
(4) neighbor class addition, perpetual
pair build: half/bin/atomonly/newton
stencil: half/bin/3d/newton
bin: standard
Setting up cg style minimization …
Unit style : metal
Current step : 0
Per MPI rank memory allocation (min/avg/max) = 8.817 | 8.820 | 8.822 Mbytes
Step Temp Lx Ly Lz Press Pxx Pyy Pzz PotEng TotEng Enthalpy Volume Density
0 0 52.216236 52.216236 52.216236 -45557.926 -47746.027 -44066.905 -44860.844 -4.9107505 -4.9107505 -5.404925 142369.41 7.2503239
19 0 52.216236 52.216236 52.216236 nan nan nan nan nan nan nan 142369.41 7.2503239
Loop time of 29451 on 80 procs for 19 steps with 8192 atoms
99.9% CPU use with 80 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = linesearch alpha is zero
Energy initial, next-to-last, final =
-4.91075047656185 -5.39175998754189 nan
Force two-norm initial, final = 187.24871 nan
Force max component initial, final = 15.388346 0.19915337
Final line search alpha, max atom move = 2.4977204e-12 4.9742944e-13
Iterations, force evaluations = 19 43
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 53.381 | 64.55 | 76.818 | 81.0 | 0.22
Neigh | 0.032452 | 0.033827 | 0.035448 | 0.5 | 0.00
Comm | 77.592 | 95.593 | 108.63 | 68.1 | 0.32
Output | 0 | 0 | 0 | 0.0 | 0.00
Modify | 29276 | 29291 | 29296 | 2.3 | 99.46
Other | | 0.004407 | | | 0.00
Nlocal: 102.400 ave 113 max 92 min
Histogram: 3 2 7 11 16 17 15 6 2 1
Nghost: 3093.35 ave 3121 max 3068 min
Histogram: 4 9 9 8 12 10 14 6 4 4
Neighs: 7268.34 ave 8102 max 6286 min
Histogram: 5 3 5 9 7 14 16 14 5 2
FullNghs: 2319.60 ave 5309 max 730 min
Histogram: 5 21 12 17 10 5 4 1 2 3
Total # of neighbors = 581467
Ave neighs/atom = 70.979858
Neighbor list builds = 2
Dangerous builds = 0
stencil: none
bin: none
pair build: skip
stencil: none
bin: none
bin: standard
bin: standard
Setting up Verlet run …
Unit style : metal
Current step : 19
Time step : 0.0005
Per MPI rank memory allocation (min/avg/max) = 7.692 | 7.695 | 7.697 Mbytes
19 50 52.216236 52.216236 52.216236 nan nan nan nan nan nan nan 142369.41 7.2503239
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 20 PID 58796 RUNNING AT hpc406
= KILLED BY SIGNAL: 11 (Segmentation fault)
I would really appreciate any insights on what could be going wrong and how I can fix it. Thanks!
