please *always* reply to the mailing list and not individual people. thanks.
Thank you very much sir. It worked. At first I thought that using pair_style
lj/cut multiple times will replace the previously declared commands. Thanks.
it *will*. it is irrelevant, since the only difference between the
lj/cut style commands was the cutoff and this can be (and was) set on
a per atom type pair basis through the pair_coeff command. if you
specify the cutoff in this location, the global cutoff will not apply.
