Dear professor Axel,
Thank you for timely reply! Can the command "pair_style lj/cut/tip4p/long" be used to calculate normal coulomb and automatically identify normal coulomb and tip4p coulomb? I know tip4p pair style is used to account for the ficticious charge on O atom. In my opinion, "pair_style tip4p" should be used as long as there is coulomb interactions between O atom and other molecules, such as O-Na, and "pair_style coul" should be used when there is no O atom, such as H-Na. Am I right? I am a little confused about when to use "pair_style tip4p" and "pair_style coul", especially when there is coulomb interactions between water and other molecules.
Best wishes,
Xiaohui
