I am currently trying to implement a nb3b/screened pair_style but it seems that the lammps documentation has not been updated since I was unable to find what the format of the potential file should be. Therefore, I tried to do something similar to the nb3b/harmonic potential file but changing the last columns from cutoff to rho1 and rho2 (E=K*((theta-theta0)^2)*exp(-rij/rho1)*exp(-rik/rho2) : #i j k K/2 theta0 rho1 rho2
S S S 0.00 0.00 1.0 1.0
S S Ge 0.00 0.00 1.0 1.0
S Ge Ge 10.0 90.0 1.0 1.0
S Ge S 0.00 0.00 1.0 1.0
Ge Ge Ge 0.00 0.00 1.0 1.0
Ge Ge S 0.00 0.00 1.0 1.00
Ge S S 40.0 109.00 1.0 1.0
Ge S Ge 0.00 0.00 1.0 1.0
Then, the simulation run but no angular correction is seen in my system compare to similar system but with the nb3b/harmonic pair_style.
The file format can be inferred by comparing the two example files in the “potentials” folder.
The file potentials/MOH.nb3b.harmonic has the entries:
# these entries are in LAMMPS "real" units:
# k [kcal/mol/rad^2], theta_0 [degrees], cutoff [Angstroms]
# format of a single entry (one or more lines):
# element 1 (central atom), element 2, element 3,
# k_theta, theta_0, cutoff
# (ijj)-->determines cutoff for i-j distance
# (jik)-->determines k, theta_0 for i-j-k angle term
# ielem jelem kelem k theta_0 cutoff
O O O 0.00 0.00 0.00
O O M 0.00 0.00 0.00
O O H 0.00 0.00 0.00
While the file potentials/PSiO.nb3b.screened has the entries:
# These entries are in LAMMPS "metal" units:
# Format of a single entry (one or more lines):
# k_theta, theta_0, rho, cutoff
# i j k K theta0 rho cutoff
O P P 32.5 109.47 1.0 3.3
O P Si 60.0 109.47 1.0 0.000
O P O 0.000 0.000 1.0 0.000
O Si P 60.0 109.47 1.0 0.000
So your modification is apparently incorrect, since there is only one entry for \rho and your file is incorrectly setting the cutoff.
Thank you very much for your prompt answer!
This answer my question about the file format and also the change of units between harmonic and screened pair_style wich was also a problem I had.
So, to make sure that I have understood the nb3b/screened pair style well, could you confirm that it basically behaves like the harmonic one, but instead of having a “brutal” cutoff of the harmonic potential, it is done more smoothly thanks to the screening of the exponential?
Thanks again.
The pair style does what the documentation says it does. I am not going to give you a digested version of that here. If you do not trust the documentation, feel free to set up some test inputs where you can compute the results yourself ‘by hand’.
