Good morning,
I am doing a project involving TTM, and specifically TTM/mod. When I run TTM/mod it gives me the following error:
ERROR on proc 1: FileReader should only be called by proc 0! (…/potential_file_reader.cpp:54)
Last command: fix 3 ALUMINUM ttm/mod 123456 ttm_mod-Al.in {NxA} {NyA} ${NzA} infile simpleTTM3.txt outfile 100 T-Al.out
It appears that TTM/mod does not work with parallel computing: the code runs fine if using just one processor. Regular TTM and TTM/grid work with multiple processors so only TTM/mod gives the error with multiple processors. Any idea what may be causing this and how to fix? Thanks!
